Will i need an HO alt?
Username: Dropthatbass
Minnesota US
Post Number: 73
i have a SX 12-1000rms and a hifonics titan tx1505d- 1500rms and i have 2 extra batteries in my trunk and i was wondering if i could get away w/o blowing my altanator?
Username: 54danny54
Post Number: 1123
it wont blow ya alt...it will put alot of strain on it though...adding another battery MIGHT help
Username: Tdbdadrummer
Post Number: 749
Extra batteries and caps won't help voltage drops and such. The only way to fix that is to A.) Get a H/O alt. or B.) Get an extra alt. installed.
Minnesota US
Post Number: 74
thanks guys (its actually a pretty new alt. my grandma put in it haha cause it was her car but idk if that would help but maybe)
Username: 54danny54
Post Number: 1126
if i was u id take the time 2 pitch in sum $$$ u could get a great 200 amp alt wich is plenty www.excessiveamperage.com
Username: Invain
Michigan United States
Post Number: 4092
If it's a stock alt. then yes you'll probably need a bigger one. Two more batteries isn't gonna help at all... how do you think they're gonna get recharged?
