Question about clipping
I got a 4 channel amp. 2 front channels for components, 2 back channels bridged to power a sub. My question is if I have bass boost off, and have my HU equaliser at default setting, should my front components and sub theoretically start clipping at the same time if I turn the volume up high??
Here's another scenario, if the bass is turned up on the HU or the amp, and I have the volume loud enough for the sub to clip, Is the amp gonna be sending a clipped signal to the sub and components? or just the sub?
"Here's another scenario, if the bass is turned up on the HU or the amp, and I have the volume loud enough for the sub to clip, Is the amp gonna be sending a clipped signal to the sub and components? or just the sub?"
Well duhhhhhhhhhhhhh!!!
both components and sub are hooked up to the same 1 amp right,its common sense dude your wasting peoples time.
