My amp light fades out and i can't get it working
Username: Brownbrotha
Niagara Falls, Ontario Canada
I'm pretty sure all the wires are hooked up fine. I've checked the wires over so many times. Do you know of any reason why when i hook up my amp the power light on the amp turns on and fades out in a matter of seconds. I took of the remote wire for a few minutes then hooked it back up and it did the same thing. it won't stay on. I know the amps not fried because i've used 3 different amps that work and in each one the light fades. Why does this happen?
Username: Lexuscoop
Post Number: 126
try and ge the rubber off the power wier just a little bit more and like get it all the way under the screw.... that sounds rong in so many ways....
Username: Lexuscoop
Post Number: 127
