Is there a trunk pin switch input on the Viper 791XV?
Username: Jprix82
Post Number: 401
Is there a trunk pin switch input on the Viper 791XV if so where would i hook it up at?
Username: Ruthless06
C-ville, Va USA
Post Number: 111
I can't remember exactly. I will check the manual in a little while and get back to you.
Username: Jprix82
Post Number: 410
ok cool
C-ville, Va USA
Post Number: 112
the blue wire on the main harness is trunk input, it is negative.
