New member Username: JkidderSpring hill, Florida Usa Post Number: 2 Registered: Nov-05 | i am going to have a lot of spl with my 2 kicker l7's so wat r some good 5x7/6x8 speakers that wont be drowned out due to my bass? |
Silver Member Username: TheelfkeeperStockbridge, GA USA Post Number: 632 Registered: Feb-05 | its power you need to "keep up" with the L7's. and a set of speakers that can handle the power. component or coaxial speakers?? Alpine,Boston Acoustics, MB Quart, JL Audio and Infinity are the only brands i know of that make decient speakers of that size. i'm sure there are others. a few of them also have component speakers in that size too. |
Silver Member Username: Nutty91rsBloomington, Indiana USA Post Number: 302 Registered: Oct-05 | These will keep up, they come with adapter plates to fit them in 5X7 openings. http://cgi.ebay.com/PHOENIX-GOLD-X5-0-5-1-4-XENON-COMPONENT-SPEAKERS-NEW_W0QQite mZ5837665557QQcategoryZ32818QQrdZ1QQcmdZViewItem |
Silver Member Username: TjmutlowPost Number: 242 Registered: Sep-05 | better use an amp on whatever you buy. |
