Have anyone have experian with this Subs?
Username: Sig
Hi guy's have anyone of you guys have experian with the MTX thunder line: 7500, 8500 & 9500? are the 8500 good subs?
And wich one of these 3 setups will be the winner 4 12" MTX 7500, 3 12" MTX 8500 or 2 12" 9500 series, all of them in sealed box, and the apropiate power and volume enclosure for each of them. On the MTX site if you compare these 3 setups the 3 12" MTX 8500 series will be the winner because of more Volume Displacement, if you compare the 4 12" 7500 agains the 3 12" 8500 the 3 12" 8500 will be 0.47 dB louder that the 4 12" 7500, and if you compare the 3 12" 8500 against the 2 12" 9500, the 3 12" 8500 will be 2.44dB louder than the 2 12" 9500. And if you compare the 4 12" 7500 against the 2 12" 9500 the 4 12" 7500 will be 1.97dB louder. In my opinion the setup of the 3 12" 8500 will be the best of these 3, because it's louder and it required less power the 4 12" 7500 required 1600 Watt Rms, the 3 12" 8500 required 1500 Watt Rms and the 2 12" 9500 required 2000 Watt Rms, So what do you guys who did have experian with these 3 models of MTX Subwoofer think about this? Are the MTX 8500 series an good Subwoofers? or it is just specs? thanks guys.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 626
refer up to the like 3 other posts about MTX subs
