$350 budget setup
Username: Xstokes88
Tacoma, Washington United states
Post Number: 7
so im lookin for subs that will be louder and have deeper bass than my current setup. i have 2 pioneer 12" 400wrms dvc's i was lookin at the memphis mojo but thats a little pricey for me im on about a 350$ budget and the mojo i was lookin at was $385 and i still need a box.. anybody kno where i can get one cheaper than that or anything else thats better than my current subs that still fits my budget?
Username: James1115
Wilton, Ct
Post Number: 4285
what amp do you have now?
Username: Xstokes88
Post Number: 8
i have a legacy 3000w mono amp.. i kno not tha best or even close but it was only $50 from my cousin...
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 227
15" re SX...i have no clue what that amp does but the SX is cheep and loud
Username: 54danny54
Post Number: 1068
i agree wi th jake
Username: Xstokes88
Post Number: 11
so that one 15" should hit harder and have deeper bass than the subs i have right now? but i dont kno if a 15 would fit in my trunk
Username: Metalhead88
Ep, Nj Usa
look at some new subs on ebay (dont ever buy anything used on ebay) you could get urself a pair of kicker compvrs for about 100 bucks... they also have an all in 1 combo...300 watt tweeters..wireing...2 12'' kicker subs a 4 channel 1600 wat amp and an enclosed box...all for 300 bucks...a price u cant beat
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1934
the amp, tweeters and the enclosure they give u are crap. So take the other 200 and get better equipment
Post Number: 1935
Also Xavier what kind of car do u have
Username: Xstokes88
Post Number: 13
i have a 1990 honda accord ex
Post Number: 1937
http://cgi.ebay.com/ebaymotors/2-KICKER-COMP-VR-CVR12-12-SUBS-LOADED-BASS-BOX-L- K_W0QQcmdZViewItemQQcategoryZ38647QQitemZ8017247904QQrdZ1
http://cgi.ebay.com/2005-AUDIOBAHN-A8000T-INTAKE-MONO-AMPLIFIER_W0QQitemZ5832294 357QQcategoryZ64571QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Pretty good budget system
Los Angeles, CA USA
Post Number: 854
thats pretty good chauncey.
Username: Rovin
Trinidad & T...
Post Number: 2995
agreed - hope the box performs as good as it looks though but 4 that price its a steal ........
Username: Scocho
New Hampshire
I'm in the same situation as far as budget, and I was considering getting either those Kicker subs or some JL W0's. My goal is sound quality, and I listen to mostly metal & rock, and some rap. I have a 2000 Accord coupe, and my amp is a Rockford Fosgate Punch 55.2. Would you recommend either of those subs? And would it better for me to go with 10"s? Any help will be greatly appreciated.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1670
w0 for sq. no kickers for that purpose.
12's will go lower than the 10". if you have adequate power and space, go with the 12".
no, your sq won't suffer.
Username: Scocho
New Hampshire
Thanks for the response! I now really want to go with the JLs, and I saw this JL 12" PowerWedge for $250 (including shipping):
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14482
I thought I saw the same thing somewhere else for $310:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2917
I thought that first one looked like a pretty good deal, but then I noticed it had an RMS range of 125W, and the second had 250W. Does this mean the first link only incudes one 12"? Any advice?
Username: Malcantry
Post Number: 14
12's will give you a more deeper and longer bass sound that is slower to react.
if you listen to metal/rock more than anything i suggest 2 10's because they are more responsive and play with better sq for that genre.
Ep, Nj Usa
if u listen to metal defenatly go with the 10s...12s tend to get sloppy with the double bass and u get a deaper tone with the 12s witch really isnt nessasary for that kinda music....10s will be plenty loud enough and will sound better and they will also have more ''thump'' then the 12s
Username: Scocho
New Hampshire
Thanks for the advice, guys. I think due to the low RMS on my amp, I'll be going with 1 10", most likely an Elevation Audio Comp10, with a sealed box. Do you think this is a good choice?
