Whats that whistlin' noise??
In my ported box if i turn it up to loud or if there is a specific type of bass on it makes an annoying whistlin noise what is it??
Username: Young_james
Post Number: 245
i think that's just called port noise.....most all ported encloseures do it. How bad is it? It could also mean that your box is leaking somewhere.
Username: Jmloughrey
Farmington, CT
Post Number: 1412
that'd be port noise.
Username: Araknid
BOCA , FL U.S.
Post Number: 1221
Yeah ported boxes and bandpass do that. The frequency it does that with is different for each box depending on the box type and tuning.
Username: Redskin
LondonEngland
Post Number: 229
To little port area=port noise.
Username: Disturbedpriest
Post Number: 185
When you redo your box, make sure to round off all the corners and that will help you to eliminate port noise. (all the corners of your port that is)
