Box Stuffing
Kyle D
What does this do in terms of sq and spl? Does it work for both sealed and ported? Thanks
Username: Mobster
Post Number: 15
allz i know is it doesnt increase the spl but the sq is better. you can do it for both types of boxes but u have so put a like mesh grill or something like that over the port to stop the stuffing to be blown out.
Username: Nnnnick_b
Nc Usa
Post Number: 370
Stuffing or lining a box with poly fil makes the box appear larger to the woofer. A stuffed sealed box will play lower then the same box not stuffed because stuffed appears larger to the sub. Can be used in most box designs.
