Repairing a broken sub
Username: Jaguar600
Post Number: 36
hey guys, I recently blew my 15 inch kicker, I was wondering is there anyway to fix it? it blew around the top edge, the like rubber seal came off. Can I just glue it back on or something?
a l e x farris
did u blow the voice coil? fixing the surround wont help a blown coil...
Username: Jaguar600
Post Number: 37
uhh I dont think its a voice coil, its the rubber part around the sub that moves
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1703
the surround
a l e x farris
when you blow a sub u blow the coil, anyways does it sound distorted when you play it?
Username: Mikechec9
Post Number: 1704
"blow" the coil? there are a number of different ways to blow a sub. pushing it beyond its mechanical limits is one of them. the surround is just one of the sub's mechanical component. damaging the coil can be either thermal or mechanical.
Username: Jaguar600
Post Number: 38
the surround is the part that is broken. is there a way to fix that?
Yea...wave ur hand over it and say abra cadabra.Obviously with glue dude!?!?!??!Damn!!!
a l e x farris
heres some surround glue, not for shure witch one you should get
http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=3
Username: Jaguar600
Post Number: 40
link didnt work :-/
a l e x farris
go to www.partsexpress.com and then search for glue. thats what i did
Username: Audiowizard69
Post Number: 32
that works man. I couldnt wait on the glue forever so i just bought some automotive silicone and fixed mine. i looks sh!tty but sounds great
Username: Redliner
Post Number: 41
what happens if you put a hole in the surrounding with a screwdriver I ave a friend that did should he just use the glue
Username: Alex_f
Lawrenceburg, Ky Us
i have did that before, but it did not change the sound
Username: Redliner
Post Number: 42
oh ok just wondering because it didnt seem to sound any diffrent so I was just wondering
