What kind of LOC do I need?
Username: Gubbar924
Post Number: 12
First, let me apologize if I posted this in the wrong forum!...
I'm planning on adding a single Diamond Audio D612D2 sub and a Diamond Audio D61000.1 amp to my Accord sedan. I still have the original factory HU in my car. What kind of LOC would you guys recommend? I hear there are some that are as cheap as 20 bucks, and then theres the JL Audio's CleanSweep that costs 300+ !! To be perfectly honest, I dont know if/when I'll get an aftermarket HU.
So what LOC should I get? Also, where can I find it at a good price?
thanks!
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1645
www.audiocontrol.com has one as well. it's already not going to give you the complete signal that an HU will provide, but you definitely don't want anything cheap that just connects to your HU. you need something that will process (de-process) and boost your signal adequately. so, i would recommend JL or audiocontrol (subsequent to a true aftermarker HU of course).
