New amp...
Username: Soccer
Post Number: 20
What about me buying a Soundstream Davinci? Anyone know them? They any good?
TIA!
Username: Soccer
Post Number: 24
A velocity would also be nice, but expensive...
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2340
I wouldn't waste time with anything from blaupunkt myself.
what are you looking for in an amp?
what sort of power? how many channels?
what will the amp(s) be driving?
Username: Soccer
Post Number: 25
Well, since I'll still have 2 available channels in my alpine, i'm thinking of a 3-channel amp around 200W each ch. with loads of current to drive the Proaudio speakers, and a sound quality similar to my alpine...
TIA
Username: Soccer
Post Number: 26
Oh, and the 3rd channel would drive a sub, something like a 12" Pioneer...
TIA
Username: Soccer
Post Number: 27
Which I think would all come down to a high power class T amp, wouldn't you say so? I mean, I'm trying to avoid class D amps...
TIA
Username: Soccer
Post Number: 28
And a new alternator, of course, around 25oo-250 amps...
TIA
Username: Glasswolf
Post Number: 2362
class T is class D. there really is no such thing as class T. its a marketing term.
if you want 200w x 2 from an amp, that's going to be expensive.
look at a Kicker KX800.4
that's 100wRMS x 4 @ 4 ohms, but bridged, you'd get 200wRMS x 2 @ 4 ohms. the amp is around $250 US
for the sub, look at a matching Kicker KX600.1
that'd give you 600wRMS x 1 @ 2 ohms which would handle a pair of 300 watt 12" subs or a single 4+4 ohm DVC 12" sub rated for ~600watts very well.
Username: Glasswolf
Post Number: 2363
oh and if you want to go really high end, look at Zapco (www.zapco.com) for both amps.
look at the Reference and Competition C2K line amplifiers.
they make fantastic class AB amps, and some of the best class D sub and full range amps you'll ever find. Especially if you choose to match them to their SymbiLink components for signal processing and equalization.
my next system will use 2 C2K amplifers and their pre-amp/EQ.
Username: Soccer
Post Number: 29
Tks, M8!
