Whats the loudest
wholesale1
1 12" Poweracoustik MOFO
Or
2 12" Poweracoustik KSW (New)http://www.poweracoustik.com/ksw.html
CheapSPL
I would go with the mofo 12" it kicks a$$.... The Mofo's SQ is shitt but Its Expremely LOUD....
I Have a 12" Mofo on a Pd-4000 and its loud...
wholesale1
how much was all of it (sub, amp,box). and what kind of box?
PS did you click on the link?
SoylentGreen
I also have 2 mofo's and 2 PD-4000 amps. Because of the high mass of the cone do to the metal dust cap/heatsink, the mofo makes a crappy sub for sq. But, like CheapSPL said, they do get loud.
If you want cheap loud and sloppy, go for the mofo. I wouldnt suggest the KSW's for any situation.
If your on a budget, here is a pretty good sub for the money.
http://7925.adahost.com/computer/index.html?loadfile=catalog22_0.html
You cant get 2 of these for about the same price as 1 mofo and they will sound a lot better.
wholesale1
the link did not show me the sub your talking about, whats it called?
SoylentYellow
Sorry about that. In the 12" sub section its on page 5 and its the 7th one down from the top. Audiofonics.
Username: Vipersbyms
Post Number: 31
2 12" kicker comp vr's have excellent spl and sq. a pair on ebay can be picked up for $150 shipped. cant beat the price for these subs. they seem exactly what your looking for. way better than any poweracoustik or audiofonics junk.
