would 2.5 cubic feet be enough room for a RE MT12 to get loud or would a bigger box make the sub louder? if so how many cubic feet do i need...i want a box tuned to 35hz...my max box dimensions are 36" Wide, 18" Depth, and 15" Height...i will pay someone to make me box plans for my RE MT12 tuned to 35hz with as many cubic feet as possible without going bigger than my max dimensions...
man id do that for you if i wasnt leaving at 5AM. sorry im too tired and dont have time to do that right now. but yes, you should go bigger than 2.5 i would say. i would do 3.5-4 net with a large port area.
are u talking about diameter? if ur tlaking about sq in not even close. i would do a slot ported box with a port like 4 by 15. and im not sure the length right now because i dont have the program open.
is those were the max ext dimensions your interior before port and sub disp. is 4.44 cuft. this is enough room. i just dont have the time to do the whol box configuration right now im sorry. im going to bed.
