I have a mono amp how many watts are going to each voicecoil?
Username: Lilflippy
i have a audiobahn mono amp and it pushes 1200 watts rms to a 1 ohm load and it is connected to two 15inch 4ohm kicker L7's i was wondering how many watts is going to each voicecoil?
Username: James_g
TN
Post Number: 424
Those are dual voice coil, correct?
Each coil would get 1/4 of the total output from the amp. If the amp is putting out 1200w RMS, then each coil is getting 300w RMS.
Username: Tjmutlow
Post Number: 225
that would be, if that amp puts out 1200, it probably is rated for that at a certain voltage, doubtful it is rated for stock charging system.
