Bronze Member Username: Subman15Lwarenceburg, Kentucky United states Post Number: 58 Registered: Nov-05 | here is a link to a sub at partsexpress, its funny http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=299-140 |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 1787 Registered: Jul-05 | im not sure why they would even sell those, i bet they have every one they ever stocked |
Bronze Member Username: Ford123Post Number: 16 Registered: Nov-05 | that thing is bigger than the mtx jack hammer!!!! take a look at the size of that magnet |
Silver Member Username: BestmankindLos Angeles, CA USA Post Number: 691 Registered: Oct-05 | lol tim. my 6x9 has a bigger magnet than that. |
Gold Member Username: AraknidBOCA , FL U.S. Post Number: 1179 Registered: Nov-04 | wow i bet you can take home some 1st place tropies with that badA$$. |
inafia Unregistered guest | that magnet is about the size of my 1 inch tweeters |
Gold Member Username: RovinTrinidad & T... Post Number: 2837 Registered: Jul-05 | i'm gonna buy 10 of them & go DB drags - i'll power each sub with 1 Discman ....![]() |
Gold Member Username: RovinTrinidad & T... Post Number: 2838 Registered: Jul-05 | Hmmmmm - 3.4 pounds EACH ! - OMG , those are some HEAVY fuQers ! ....... |
Silver Member Username: MixneffectOrangevale, Ca. USA Post Number: 536 Registered: Apr-05 | That is a replacement speaker for old systems that used paper cone woofers. The magnet is not that big because it doesnt need a big magnet for the weight of that cone. Paper is much lighter than polly/alluminum/magnesium, etc... It is a relatively high efficiency woofer at 91 dB for the application it is used for. Remember this is not a quality speaker. It is probably used in a P/A system and or integrated designs such as Fisher, Sounddesign; stuff that doesnt exist anymore. It is just a replacement woofer. The amount of SPL some guys build in their systems on this forum; this 12" woofer would make a great mid-bass driver for you. You would probably need like two sets of paralell-series quads. At 80 watts rms and 91 dB each, these puppies would rock between 70-600 Hz. |
Gold Member Username: James1115Wilton, Ct Post Number: 4233 Registered: Dec-04 | exactly Mix those subs are actually quite loud when used in the proper application. Yes they dont have a ultra low FS but like mix said between 50-600 hz they do get pretty loud, and dont need much of an enclosure to do it. |
