Sealed or ported?
im putting 2 10"s in my truck extended cab and was wondering should i seal the box or port it and alos which way should i face the subs for best spl and sql?
Username: Audiowizard69
Post Number: 21
put them in a sealed box and face them down. that should accomplish ur standards
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 312
what kind of subs do you have and also you could face the subs down. down firing boxes work very well in trucks and suv's
Username: Ford123
Post Number: 17
i have 2 mtx 9500 10" 4 ohm dvc running off an mtx 81001 ( 1500 watts at 1 ohm) this should be ok right and it should sound decent ... i hope
Username: Ford123
Post Number: 18
and also is it ok to put a piece of 3/4" plexy glass on the top instead of the top piece of partical board so i can see down into my downfire box or is that a bad idea...because i wanna see the woofers and i wanna customize the hell outta my box...(me and my dad are building it and i own a counter top business so i have all the resourses neccessary...)
