Clay8960 Unregistered guest | I have 2 JL 12w3v2 and i was wondering what you think the best amp for them is. I was looking at the Orion 600D monoblock amp.. is that good for them? |
Gold Member Username: RovinTrinidad & T... Post Number: 2512 Registered: Jul-05 | https://www.ecoustics.com/electronics/forum/car-audio/174997.html so get double the 250/1 which is 500/1...... |
clay8960 Unregistered guest | the 500/1 may be to expensive looking for price around $250. any other suggestions? would it be worth it just to spend the extra money for the 500/1? sorry i dont know alot about amps and subs |
Silver Member Username: BestmankindLos Angeles, CA USA Post Number: 488 Registered: Oct-05 | you won't regret it if you get that amp. besides jl subs and amps go great together. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 1459 Registered: Jul-05 | JL subs= Peanut Butter JL amps= Jelly |
Silver Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 284 Registered: May-05 | i like that chauncey very true ![]() |
