CompVRs vs. alpineR
Username: Bga44
Tampa
Post Number: 127
what would have the best SQ? and what would have the best SPL?
the CompVrs are cheaper. im looking to buy 4 12"s. what do you recommend.
Username: Bga44
Tampa
Post Number: 128
or how about RF punch2,JBL power, or kicker L5?
Username: Taylor17
Kopperl, Texas
Post Number: 3257
What are you exactly looking to get out of these subs?
Spl, sq, or both?
The L5 will have the best spl... but it will have the worst sq...
Personally, I like the type R's.
The CVR's are pretty close to the R's though...
Username: Rovin
Trinidad & T...
Post Number: 2435
since u have space for 4 12s - y not do 2 15" type Rs ,good price on ebay .......
Username: Bga44
Tampa
Post Number: 130
2 15" Rs. I want good both. i want it to be loud enough, but not sound like crap
Username: 54danny54
Post Number: 976
id go with compvr's
Username: Bga44
Tampa
Post Number: 131
i want to spend around $600 total. the 15 compVRs are around $100 each. the 12" Rs are around $120 each. both take i think same RMS. which would be better. Or what about 2 15" L7s?
Username: Bga44
Tampa
Post Number: 132
15" L7s run around $235 each and take 1000RMS. i could get two of those which would be 2000RMS @ 1ohm(if both dual 4 ohm). or i could get 4 12" Rs which is 500RMS each, total of 2000RMS. same as L7 RMS. which would be louder out of those and have better SQ
Username: Jakeyplaysbass
Post Number: 196
2 RE SX 15's and a 2000 watt amp will be the best. 4 12" type Rs or compvrs would be my second choice. i would stay away from L7s if you want sq.
Username: Bga44
Tampa
Post Number: 133
wut amp would u recommend for the RE SX 15s?
Username: Bga44
Tampa
Post Number: 134
i cant find SX subs online. ill probly go wit the Rs. most people dont like L7s, they said the SQ is complete crap
Username: Cenus
Hicksville, Ohio Usa
Post Number: 644
either the cvr or type r will have good sq and good spl. personally i would go with the cvr but either sub will be a good choice.
Username: Nickboarder27
Inland EmpireUSA
I'd be lookin at two 13W7s from JL
and two 1000/1's to power them.
cost prohibitave purhaps
