Optima redtop vs. yellowtop
Username: Iufan4lifeul
Post Number: 753
My battery (stock) is going bad and I need to replace it! I can't decide between a red or yellow top. It will be my main starter battery but I want as much CCA and reserve as possible for my audio system. What would you all recommend? I have been told, for my application the red top should do the job and generally a yellow would be like for a battery bank for when the car is off.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1334
yellow top, i heard they where going to stop makin them, but yellow tops are better
Post Number: 755
any reason in particular they are better?
Post Number: 1338
yellow tops are made for car audio
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1513
yellow and blue (marine) tops are deep cycle batteries inteded for repeated recharging after draining with no ill effects.
red tops allow for quick current distribution. in two battery set-ups, you would ideally run a red for while the car is started, and a yellow for while it's off.
there are better alternatives to optimas though. they were never made for car audio. they just ended up going that route.
it, like isolators, were designed with RV's in mind. i would like a kinetic battery, personally. just can't quite afford i yet.
