JBL 1200.1: will this fry my subs?
Braden N.
i have two 10" Audiobahn Subs (Dual Bandpass System) rated @ 2 ohms, 600w RMS. if i turned the vol. up 50% would a JBL 1200.1 fry my subs? If so, how about a suggestion for an amp that would fit these subs for around $200-300. Thanx in advance.
Username: Rovin
Trinidad & T...
Post Number: 2235
turn the gains 1/2 way up as a precaution as well as keep your volume down too .
this amp would work well with it
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15169
however - IMO . i would get rid of those subs & instead of buying a new amp , spend that money on a pair of Alpine type R 2ohms DVC subs ........
Username: Rovin
Trinidad & T...
Post Number: 2237
"turn the gains 1/2 way" - i meant to type , turn it down low
Braden N.
thnx, but is that the cheapest i could find that amp?
Username: Rovin
Trinidad & T...
Post Number: 2243
No ,search - i was just giving u an example of a good brand .
Check Hifonics bx1205 if $ is low ........
