Mtx vs ma audio
Username: Ford_on_20s
Jacksonville, Florida Us
im about to put some new subs in my f-150 and im reseaching trying to find the best. i heard a 15'' ma auido hk12x2 today and man it pounded , but ive also heard that mtx is better so i was wondering which sounds better and has deeper bass
Username: Rovin
Trinidad & T...
Post Number: 2104
MA vs. MTX
MA is on the right , MTX is on the left
MTX wins by a TKO - its always the better brand
thx alot rovin....would u recommend 7500 series or 8500 or what do you think is better ?
Username: Rovin
Trinidad & T...
Post Number: 2105
Depends on how loud u like your bump & how much box space is available too .
If its a single 15" i might go all the way with the 9500 - if its 2 want then 2 8500 should be enough noise .
The Alpine 15" type R is 750wrms & is considerably cheaper so to are Diamond Audio D6 & D9 series subs ......
Post Number: 7
thanks alot for your info and time rovin lol but just one final queston and your good to go lol..i already have a dual 10'' ported box..could i stick 2 of the 10'' 8500's in there or would i need a different box or would i be better off spendin little more and gettin 2 12's ?
Username: Rovin
Trinidad & T...
Post Number: 2108
Its cool since nothing good on the Telly right now -lol
I personally would choose 2 12 anyday over 10s cause i like it low & louder . Better the subs bigger than too small -eh ..lol
Do consider the Alpine,Diamond,RF P3 & Mmats P2.5/P3 subs as well .....
Username: Rovin
Trinidad & T...
Post Number: 2113
I replied but thread still have not shown that i did & bumped it to the top ......
Post Number: 8
well guess i lied earlier...still a couple more questions in me lol...do you think a mtx 15'' single 9500 would sound better than 2 12'' 8500's which coice would you go with
Post Number: 9
i lied earlier lol still got a couple more questions in me...a single 15'' 9500 or 2 12'' 8500's which would you say is better choice?
Post Number: 10
ok comp must be screwin up came up 2 times here
Username: Rovin
Trinidad & T...
Post Number: 2119
well i prefer 2 sub set-ups so i'm biased to that - coil choice depends on amp u buy but generally 4ohms DVC subs is the norm cause it brings down the load to 1ohm & 1ohms amps are a bit cheaper mostly than 2ohms amps .......
catch u tomorrow , i'm off to Upload
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 374
one 9500 pwnts 2 8500...lmao...nah but seriously their are several other alternatives such as Alpien and Eclipse subs but if your wanting to go mtx the 8500s are alright but the 9500 is insanely loud and it sound pretty good too
Username: Quickshot
Post Number: 375
umm rovin in your little animation the guy on the left(mtx) actually is the one that lost just though ill point that out :-)
Username: Rovin
Trinidad & T...
Post Number: 2121
Upload - MY MISTAKE !
Was thinking 1 thing & typing another Upload
, my bad ....
Here , let me correct it - Upload
MA vs. MTX
MA is on the left - MTX is on the right
MTX wins by a TKO - its always the better brand !!!!
