Visonik: Good or bad?
Braden N.
I found a Visonik amp (mono channel) that gives out 900w RMS at 2 ohms for about $180. Is this a decent brand of amp or is there any other brand of amp w/ 800-1000w RMS of power around $200 that would be better?
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 378
Visonik is considered bad although some fot heir stuff is ok...overall i wouldnt buy it..the cheapest reliable amp i can think of would probably be the JBL 1200.1 off ebay
Username: Nutty91rs
Bloomington, Indiana USA
Post Number: 107
Visonik amps are built to very low standards, they may sound good for a minute but it's not going to last. I say go for a Rockford, Phoenix Gold, Kicker, or a Kenwood, all of them can be hard in that price range.
Username: Tdisanto
Post Number: 484
Your not going to get that kind of power for that kind of money from brands like Kicker.
Your looking for cheap power and I would suggest the best brand that is cheap power would be Hifonics. Theyre probably the best sh1tty brand.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1040
Audiobahn, and Hifonics are also good on a budget
Username: Nutty91rs
Post Number: 111
True you're not going to get 900RMS watts from a decent manufacturer for $200. Do you really need that much power?
