Bumpin' while vehicle off
DUB
I wanna know of ways I can listen to my system for longs periods of time while my truck is off and not run down the battery. What can I do to do this?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1490
turn it down...your batt will last a lil longer.
other than that, a better or extra batt is the only option.
Username: Rovin
Trinidad & T...
Post Number: 2063
Like he said - more batteries ....
Username: Fandim
Reno, Nevada United State...
Post Number: 393
If you want to do this, you will DEFINATELY need to isolate the starter battery, and get a deep cycle 2nd/3rd/4th/5th/6th etc battery... Running a normal battery down passed 10.5 volts will cause permanent damage, almost immediately. Also, if you actually want to start the vehicle afterwards, the isolator is again, essential.
Just to let you know, an extra yellow top, when my car is not running, will only play my system for around 5-15 minutes depending the type of music I'm listening to. So if you're running a serious system, and want to listen to it for longer than a few minutes.. You're talking battery bank man. Hope you have plenty of room. :-)
Seth
DUB
D@mn, so an extra battery then, I am running about 800 watts RMS.
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 368
stop being cheap with that gas money and crank that b!tch LOL
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 960
lol
Username: Insearchofbass
Post Number: 3644
get a generator LOL and save that gas LOL
