Got the subs, need the amp
Username: Glacier
i got 2 Kicker cvr10's 4ohm, 300 rms 600 peak.
the amp i'm looking at is a Kicker 04KX350.2 (175 x 2 Watts/Channel - 2 Ohm Stereo; 350 Watts/Channel - 4 Ohm Bridged Mono)
is that a good amp for those subs?
Username: Tjmutlow
Post Number: 91
If those are single 4ohms then that amp is really cut in half, you can not bridge it. I have a Alpine MRD-M605 that I am selling, two weeks old with box and paperwork, puts out 400w@2ohm at 12v. It would be great for those subs if they are single 4's, I ran that on 2 JL 10w3. Amp is $210 shipped
Username: Cenus
Hicksville, Ohio Usa
Post Number: 598
that is severaly underpowering those subs, i would look at a kicker kx850.2, or or mabey a kx1200.1 depending on how much you want to spend.
Username: Robert_d
MIA, FL USA
Post Number: 294
all cvr's are dvc
he needs a 600rms at 1 ohm mono amp
or a 600rms 2 channel amp
my 2 picks would be
PG xenon x600.1 (600rms at 1,2,4 ohms) so you dont have to worry about wiring it , its also underrated
or a kicker kx550.2 , also underrated
Username: Kingsvt
try a soundstream VAN GOGH 600.2, a great sounding amp, cheap on ebay. 300rms x2 2ohm load
