Two quick questions
Username: Sony224422
Deep River, CT US
Post Number: 254
I have a bass boost control thing, and i was wondering if when its on maxium does it turn the gain up all the way on the amp no matter where its set?
Im having a problem with my amp clipping or loosing power, im not sure which it is, because sometimes it burps on songs that hit hard, but when its turned down lower, it doesn't do it. I'm not using the right size wire for it, so i was thinking maybe the wire is too small and it can't get enough power or the amp is clipping.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 935
The bass boost control thing, override the gains on your amp, and u should always use bigger wire
