Ported box or Inclosed?
Username: Tomdaman
Im putting 2 eclipse's 12" my trunk.
I use to have a bandpass box with 2 12" pyramids in it, and it sucked worse then a inclosed box with 2 12" lightning audio 100rms in it!
So im wondering if I should use a ported or inclosed for these subs. Ive got dyna mat in the trunk and a spair tire up on the uper part of the trunk, and I cant take that out.
So please help I dont which box will work better!!!
loud01
1 dual 12" slot ported box should give you an extra 3 db's if it fits.
Get the box dem. 1st
Username: Tomdaman
1.63 total cubic feet per chamber
11-1/16" mounting hole
36" wide x 13.5" high x 15" deep
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14945&item=3092638200&rd= 1
Username: Tomdaman
This box and the one in the other post are the 2 ported im looking at.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14945&item=3091695676&rd= 1
