Air Space Formula
Username: Panache
Brenham, TX US
Post Number: 13
Can someone tell me the formula that is used to determine air space. LxWxH / something?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2026
L x W x H is volume, and you need to subtract driver displacement after that.
port volume as well if the box is vented.
12inch
and the driver displacement is what
Username: Glasswolf
Post Number: 2050
depends on your driver.
should be listed in the T/S specs of the speaker.
it's the amount of air or volume the speaker displaces or takes up in the box.
when you put the sub in the box, that decreases the actual airspace in the box. in essence, making the box smaller.
same goes for port tubes.
