Help installin' a HU thats not in a factory spot!
Username: Hex0rz
This is beating the crap out of me! I have a Pioneer Premier DEH-P670MP HU. The vehicle I wish to install it in is a Mazda B2200 X-cab 1989. I no longer have the factory mount spot, so I would like to put it elsewhere. I've seen other people do it in this spot, but I cant contact them. The HU is too small for it to fit, so I was wondering how you fit it in. The spot is a slot above the ashtray. You can take out the pocket and put the HU in. But I know things are going to have to be cut. And most likely a spacing kit.
Does anyone know the process?
Username: Illuminator
Post Number: 2099
You can just buy an install kit from Best Buy or online...
Username: Hex0rz
Ya, for a spacer kit. This spot needs a custom mod. to fit the deck. Not even the cage fits in it. But I know its possible since I've seen it done.
