Need to cover port whole or get a pipe thing. Plz help
Username: Sinx85
Post Number: 89
hey guys i got a dual 12" enclosure with 2 round ports 4" each. my cousin lost the port pipe thing so now they are just 2 wholes left and the subs sound like shyt in it. i like to cover these or get a pipe tube thing so atleat they ll sound nice.
Please tell mehow can i cover them or is it possible to buy or make the pipe.
I am in Canada GTA area.
Went to futureshop and they dont have anything :-(
any help is appreciated
thankyou
Username: Soundstreamjeep
Hickory, NC U.S.A.
Post Number: 11
Well prob. ur best bet would be to build i whole new box, it sounds like your trying to piece a box together and that isn't good. If there is anyone that builds boxes in ur area they could prob help u out.
Username: Need4bass
We-Be-Swamps, Louisiana
Post Number: 147
You are limited to 4" diameter ports, which you can buy.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=268-352
You will need to calculate the proper lenght to cut the ports in order to tune the box to the proper frequency.
