ID 10 v.3 vs IDQ 10 d4 v.2
Username: Machinist
Edison, NJ USA
I have narrowed it down to these two subs, is there a big difference between the two besides $40? They will be going into a .65 sealed down firing box under the rear seat of my truck. http://www.sounddomain.com/shop/compare.pl?comp_sku=IDSID10V3D4&comp_sku=IDSIDQ1 0D4V2&prev_query=brand%3DImage%2BDynamics%26type_plural%3DSubwoofers&x=34&y=17
Thanks
Danny
Username: Bdb_86
Bemidji, MN Usa
Post Number: 116
its a tough choice both have there good sides but i think that you should go with the ID 10 v.3 because it is closer to the air space that you well have and it is cheaper and the warrenty is one year longer
Username: Its_bacon12
Post Number: 465
i would go with the IDQ - higher xmax with same amount of watts and plus ive heard one before in a .75 cube sealed box and it was awesome with 200w rms
Username: Machinist
Edison, NJ USA
Thanks guys. Price is a big factor but so is SQ. Would one be better then the other for SQ?
Thanks
Danny
Username: Machinist
Edison, NJ USA
Thanks very much guys. I have decided to go with a single IDQ 12" in a Q logic box http://www.sounddomain.com/sku/QLCQLC1DTX112B1
I dont have much of a choice considering the room I have to work with and the fact I would loose all storage and room for the jack. It may not be the best way,but it seems like the only way to have the best of both worlds.
Thanks again for all the help
Danny
