Speaker Sound problem
Username: Jeppo
Hey, i just recently installed a new system in my car, which included 2 6x9" pioneer speakers in the rear. i have a problem with them though, sometimes my left speaker starts to make this low rattle noise that drives me insane. I can temporarily stop the noise by applying a bit of pressure onto the inside of the speaker, but it always comes back.
Any ideas on what this is or how i can fix it? cheers
Username: Solacedagony
New Jersey US
Post Number: 553
Is the sound coming from the speaker rattling against whatever it's mounted to or something mechanical on the speaker itself?
Username: Jeppo
I'd say its coming from inside the speaker itself, because when i stop the sound temporarily im putting pressure on something inside the speaker.
Username: Antney
Erie, PA Waterford
i dont know if you can drop a voice coil in a 6x9 but if its possible thats what it sounds like cause i dropped the voice coil in my 10 and it wont even work unless i put pressure on it
Username: Bumpnthump05
US
Post Number: 8
I'd Be Returning them for another pair they sound like they were no good at the start
