Philips 6 CD Changer DC022
prettypegagirl
Hi, They stole our Head Unit out of the car and left us the shuttle, can anyone tell me if it's possible to fit another Head Unit that is not a Philips. What is compatible with it? They don't manufactur the philip ones compatible with this one since 2000, please help
Username: Carguy
Post Number: 4398
Prettypegagirl, you're out of luck. You will need to get a new HU (headunit).
Those low life thieves should be hung by their toes upside down and whipped with a dull knife, then tarred and feathered.
That's not my idea, I read it in one of Shakespear's plays.
prettypegagirl
Okay, Where will I get a new Headunit, compatible with this? Or is it better to just buy a whole new system?
Username: Carguy
Post Number: 4421
Unless the one you lost is a high quality one, I'd upgrade. You do have lot of choices.
For example, Alpine and Eclipse offer different models and price ranges. If they're out of your range, then you can try Pioneer or JVC.
Just don't settle for Sony. They're a bottom feeding leeches. :-)
i have both a head unit and changer and was hoping to connect the dc022 changer to my new blaupunkt satnav head unit.
Is it not possible to get the two connected i think the connections are identical.
