Anyone ever used wellnuts threaded inserts?
Username: Dustin3
Tigard, Or U.S.
Post Number: 91
hey, this is wayyyyy off topic, but i am just wondering if anyone has used some inserts you use when you seal holes etc. It's a rubber gromit type thing and the brand is wellnut and it's a threaded inserts.
my main questio is: how tight do you tighten them?? because if you tighten them too tight wont the screw in the insert come out??? i am using them for a lugagde rack for my car...
so how tight do you tighten them, and if you havent dealt with them before dont answer saying you have because i am looking for some real help.
D
Username: Dustin3
Tigard, Or U.S.
Post Number: 95
anyone...
