Rl-p vs eclipse alumnum
Username: Hondarider
Glidden, Iowa U.S.
Post Number: 142
Which can get louder?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 613
rl-p (never heard one though) just specs wise
Glidden, Iowa U.S.
Post Number: 143
Would the kicker kx600.1 work good with a rl-p?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1131
yes but they rl-p can take more power. i would think the rl-p could get louder, however with the kx600.1 it could be close because form what i heard eclipse subs can take more then they are rated at. both are great subs you shouldnt be dissappointed. oh, make sure you get the best alluminum model available.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1328
rl-p is a louder, more accurate, better sounding sub. best to give it 7-800 watts.
Username: Mikechec9
Post Number: 1329
the aluminum is no ho though. the rl-p is just a significantly heavier hitter. one league beyond the Al.
Glidden, Iowa U.S.
Post Number: 145
thats funny because the aluminum cost more.
Usually everyone always chooses the more expensive one.
