Glasswolf
Username: Littleguy
Post Number: 76
Glass, can you tell me anything about The ppi Dcx 1000 digital crossover? I know you have installed some art series some time ago. If so are they worth the money they are asking for them. Like 650.00 or so? Thanks Steve.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10667
if you're using PPI Art series amplifiers it's a pretty sweet XO, but really the price just reflects it's age and how much stuff cost back then.
You can get an EQ or XO from Audiocontrol now that's just as good, for less money in today's market.
Username: Littleguy
Post Number: 77
Ya, i have 3 art series amps. A1200, two 450s. My head unit has non fader output, would like to find a xover with sub inputs so i can control the bass to the subs with out adding bass to the mids. Does audiocontrol have one?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10686
sure do, even offers remote sub level control.
www.audiocontrol.com
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10687
also look at a Coustic XM-3e or XM-5e as a cheaper alternative.
the "e" designates remote sub level control as an option.
lots of them on ebay for next to nothing.
Username: Littleguy
Post Number: 78
Glass is the xm6 any good? And i was also checking out audiocontrol 6xs.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10721
both are good if they fit what ya need.
just expanded versions of the smaller ones I named.
same functionality and quality
