Amp config for a single 4 ohms woofer
Username: Elpervers
I have a SVC subwoofer that is 3.9 ohms and rated 400w rms. (http://www.hsustore.com/asw1203.html). I decided to go with this unknown company because there home theater sub really kicks as...
A guys in a local shop told me that I better go with a 2 channel amp bridged to power my single sub instead of a mono, what do you think?
Any suggestion on an amp for that? I'd like around 300w rms and looking more for SQ.
Thanks
Username: Infinity_addict
Santa Rosa, California USA
Post Number: 179
the enclosure and sub itself will be the main determinanats in getting good SQ.
it's better to go with a mono class d amp. just yer overall best bet.
as far as choosing a reliable amp, do a thread search for good brand names.
Denis_A
a 2 channel amp bridged will give you a 4ohm load. So it would work. if you go for a mono amp, you will be paying almost double more money for the same amount of wattage output @ 4ohms. mono amps are usually used for 2ohm or 1ohm setups. Its up to you. A mono amp is your best bet, but at a higher cost.
About sound quality, I think your best bet would be to send a good clean 400w to 450w to your sub in a sealed enclosure.
my 2 cents.
