Al K Unregistered guest | I posted yesterday and heres what ive found... it must be one of these- TS-W303DVC TS-W303C TS-W303F They are 12 inch pioneers, and you can find them by searching the model numbers above on google and it will be the first link available from the pioneer site. How can i determine which one mine are? |
Gold Member Username: RovinTrinidad & T... Post Number: 1282 Registered: Jul-05 | i just logged on so ok i'm currently checking it out |
Gold Member Username: RovinTrinidad & T... Post Number: 1283 Registered: Jul-05 | OK - its VERY , VERY simple . GO look @ the frame of your sub & check how many terminals there are & come back & post From that i will tell u the answer ........ |
Al K Unregistered guest | im new to this, so you will have to explain what a terminal is... i didnt install them i had a friend do it for me. |
Gold Member Username: RovinTrinidad & T... Post Number: 1290 Registered: Jul-05 | U MUST read here 1st b4 i explain or give any advice 2 u .... read up on ohms , wattage , types of speakers/sub , wiring etc http://www.crutchfieldadvisor.com/S-TRINuJBLrCq/learningcenter/car/ www.the12volt.com www.bcae1.com a terminal on a sub is where the speaker wire attaches on to ... read/learn as much as u can & this'll take a while so get back 2 me tomorrow night ...... ![]() |
