Silver Member Username: Robert_dMIA, FL USA Post Number: 199 Registered: Sep-05 | 100W x 2 (4-1 ohm stereo) 200W x 1 (8-2 ohm bridged) those are its stats it says on the pg's site is it really 100 rms @1 /50 @2 / @4 ohms ? or is it 25@4 / 50@2 / 100@1 ?? |
Silver Member Username: Robert_dMIA, FL USA Post Number: 200 Registered: Sep-05 | lemme repost that .... 100W x 2 (4-1 ohm stereo) 200W x 1 (8-2 ohm bridged) those are its stats it says on the pg's site is it really 100 rms @1 @2 and @4 ohms ? or is it 25@4 / 50@2 / 100@1 ?? |
Silver Member Username: FandimReno, Nevada United State... Post Number: 286 Registered: Jun-05 | Robert - the xenon line all come with a birth sheet I believe. My 1200.1 was tested at well over 1200 RMS. And I have the little certificate, to put into my photo album and say "aww, wasnt my little amp cuuuutttee?!?" :-P |
Silver Member Username: FandimReno, Nevada United State... Post Number: 287 Registered: Jun-05 | And by the way - yes. it puts out the same amount of power at 1 ohms, as it does 4 ohms. |
Silver Member Username: Robert_dMIA, FL USA Post Number: 201 Registered: Sep-05 | =) thanx how are the xenons amps ? is it on par with a kicker amp ? there gunna be runnin components |
