Ok help me out here
so to set the gain level on my amp, put it all the way down, and then turn up my hu's volume untill i hear distortion, then keep it there, then turn the gain up intil i hear no distortion.
another question, what do i do with the bass that the deck puts out do i put that all the way down to - #'s or keep it at zero. thanks for the help
Username: James_g
TN
Post Number: 285
No....
If you don't know the output voltage from your HU, then you need to do it audibly, but not that way. Turn your gain all the way counter-clockwise. Turn the volume on your HU to "about" 3/4 volume. Now, slowly turn your gain clockwise until you hear distortion, then turn your gain back counter-clockwise just a bit.
oh i see thanks a bunch, but what about the equalizer in my deck what do i do with that bass read out, turn it to zero or -7
bump
hello anyone
Username: Illuminator
Post Number: 1934
Whatever sounds best.
