Four 4ohm subs to 1ohm??
SiX
How can I wire 4 Infinity 1230w 4ohm subs to run on a 1 ohm amp??? If I run them in series will that bring me down to 1ohm or .5ohm? And when I do this will the rms still be 300w and max 1200w?
HMM... WHAT TO DO...WHAT TO DO...
Username: Jakeyplaysbass
Post Number: 55
it will be 1ohm if they are single 4ohm subs...if they are dual 4ohm u can have it at 2ohm.
SiX
I think they're single - they only have on pos and neg terminal each. But when I do so will the wattage still be the same???
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1184
to get four SVC 4ohm subs wired to 1ohm...you would wire them in parrallel, not series.
SiX
PARALLEL - AMP+ to sub+, sub- to next sub+, sub- to next sub+, sub- to next sub+,sub- to AMP-. RIGHT???
Post Number: 1185
no...all 4 sub + to amp +
all 4 sub - to amp -
