Subwoofer diagrams..... any1 have any/ know where i can find them
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 971
i was just curious if some1 could paste subwoofer diagrams on here or give me a site that has them so i could learn about the insides of a subwoofer... if ya do thanks, preciate it.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 156
Try this
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=21&image.y=13&image=Submit
Post Number: 157
Or this
http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Rideredder
Cornell, IL USA
Post Number: 13
www.rockfordfosgate.com/products/subwoofer_features.asp
Cornell, IL USA
Post Number: 14
sorry that might not help you out. didn't read it before posting it.
Username: Treydog
hello i know this has nothing todo with the topic at hand, but i am needing some help. I just purchased a pair of orion 10 XTR subs from a pawn shop. The problem is I don't know what Ohm they are. They are dual voice coil, and states on the back of sub 500 watts. Any suggestions
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1082
http://caraudiomag.com/specialfeatures/0109cae_subwoofer/
http://www.bcae1.com/speaker.htm
unless you meant just wiring diagrams, these are pretty thorough.
Cornell, IL USA
Post Number: 17
are these them? www.cardomain.com/item/ORIXTR10S
Username: Treydog
The ones i have say orion in the center in red. I think mine are older. I don't know if that makes a difference.
Post Number: 973
thanks mikechec thats exactly what i was looking for.
the rest of you are wrong! lol... but thanks for your effort.
Username: Mikechec9
Post Number: 1091
sweet
