Aux battery
What do i need to do to add an optima yellow top in the back? Other than the battery, what else would I need? I have a 165amp HO alt, but at idle, it does NOT do the job. the amp fuse is 40a x3.. do I need an isolator? where to I get one? How do I hook it up?
bump
glass, please help
basically i need to know if i Need an isolator and if I wire the battery in series or parallel with the amplifier...
oh, and what about fuses? do I need additional ones? and do I keep the one I have at my starter battery...
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10573
http://www.wickedcases.com/caraudio/capacitors.html
http://www.wickedcases.com/caraudio/charging.html
http://www.betteraudio.com/geolemon/newmain/battcapalt/
http://www.bcae1.com/charging.htm
http://www.bcae1.com/chargin2.htm
http://www.wickedcases.com/caraudio/batteries.html
http://www.the12volt.com/info/recwirsz.asp
http://www.optimabatteries.com/
for a dedicated battery you want a battery isolator, proper wire sizes, and fusing to protect the isolator and bateries.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10574
oh and a battery box from Summit Racing or YearOne or similar.. to hold the battery.
also prevents leakage if the battery gasses by sealing it in the box.
