Concept 300 help needed!
Hi, I recently installed a concept 300 in my car. All the functions work correctly e.g. Indicator flash/unlock/lock/alrm go off but it wond turn the starter motor over?
It gives the ignition power but will not send the power for the starter back from the brain. There is starter power going to it as i have tested it when i turned over. When i turn the key back off after trying to start it it beeps once.
Any help would be much appreciated. williams@tawelfa.freeserve.co.uk
Username: Catalin
Surrey, BC Canada
Reverse the wiring into the alarm brain maybe???
