Bronze Member Username: BaseballscPost Number: 27 Registered: Aug-05 | www.bcae1.com said a second battery will only help while the engine is off. I was under the impression that it would serve a "buffer" preventing voltage rails when the alt couldnt keep up, like at idle. Am I wrong? |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 1056 Registered: May-05 | without an isolator, it actually makes charging considerably more difficult for the alternator. |
Bronze Member Username: BaseballscPost Number: 28 Registered: Aug-05 | so what will the isolator do, and where can i get one? |
Silver Member Username: Kd7nfrMontpelier, ID United States Post Number: 928 Registered: Apr-05 | It'll keep the second battery from being connected to the rest of the electrical system while the car isn't charging. |
Bronze Member Username: BaseballscPost Number: 29 Registered: Aug-05 | will the second battery help my problem when the car is at idle? |
jimjonson Unregistered guest | "It'll keep the second battery from being connected to the rest of the electrical system while the car isn't charging." So how do u charge te 2nd battery? Wont it run outta charge faster? |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 10569 Registered: Dec-03 | http://www.wickedcases.com/caraudio/capacitors.html http://www.wickedcases.com/caraudio/charging.html http://www.betteraudio.com/geolemon/newmain/battcapalt/ http://www.bcae1.com/charging.htm http://www.bcae1.com/chargin2.htm http://www.wickedcases.com/caraudio/batteries.html http://www.optimabatteries.com/ |
Anonymous | thanks boss |
