Silver Member Username: CenusHicksville, Ohio Usa Post Number: 492 Registered: Jan-05 | i need to choose a new h/u, i would like it to sub pre-amp outputs, and cost under $175 so far i have found these to choices. http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=724 or http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2642 which one is better in your opinion. |
Gold Member Username: IlluminatorUSA Post Number: 1780 Registered: Apr-05 | I would pick the Clarion without a doubt. The only thing that it suffers from (as most Clarion's do within that price range) is it lacks a high pass filter (HPF). |
nick_sq Unregistered guest | noooo...get the alpine! I cant stress how crappy clarions quality is. I owned a DXZ525, it had no output power to speak of, and got too hot. It finally went and it was not covered under warranty because it wasnt installed my a certified technition. $250 repair so i just threw it out. Then i got a 2003 model DXZ735MP. It lasted me 5 months from new, then the CD mechanism buggered up..sent it off for repairs, month later i get it back and it lasts another 3 months, then the CD mechanism screws up again! This was in the shop 4 times before i thaught forget it. Then they send me an 04' replacment (DXZ745mp) and it was almost as bad. It had poor audio quality and had all the famous clarion bugs (error messages, high temp, distorted and weak audio output) Not to mention the EXTREME heat clarion decks produce, (enough to melt CD labels in some cases) the cracking highs when the deck heats up (very distorted high frequency) and cd mechanism jamming...i had problems with ALL 3 UNITS. I sold the last clarion to avoid the headache. I baught a 150 dollar JVC which preformed much better in my opinion, and i just recently baught the lowest model alpine you can get for 125 bucks. CDE-9841..WOW, although this deck has no features it ROCKS. clean loud output power, no HEAT!. Avoid the clarion to matter how many fancy lights it has TRUST ME!!! |
Gold Member Username: IlluminatorUSA Post Number: 1783 Registered: Apr-05 | The heat depends on the car you own and where the heatsink is located on the unit...the Alpine might work better because I believe the 9841 has the heatsink on the back of the unit whereas almost all of the Clarions have the heatsink on the side (worse ventilation for some cars). I wouldn't be surprised if the JVC had a heatsink on the back as well... |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 494 Registered: Jan-05 | well i drive a jeep chereke so would the heat sink on the side work? i know my jensen H/U i got now has a heat sink on the back and it never gets hot. does any1 have more opinions on a good h/u with subs pre-outs and costs under $175? |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 498 Registered: Jan-05 | any1 |
Unregistered guest | I NEED TO KNOW COLOR&PIN LOCATION FOR A KENWOOD CASSETE KRC-208S |
BROTHERLY LOVE Unregistered guest | HELLO EVERYONE I AM IN NEED OF SOME HELP. MY LIL BROTHER JUST CUT ALL THE WIRES FOR MY STERIO IN MY 92 HONDA ACCORD. WE WERE REPLACING THE STERIO AND HE DID NOT LABEL THE WIRES. IF ANYONE KNOWS WHERE I CAN FIND THE WIRING DIAGRAM PLEASE EMAIL ME AT RYANCANTRELL@ADELPHIA.NET |
Silver Member Username: XkawnPost Number: 156 Registered: Jul-05 | ????thread-jackerz???? get a thread of your own... dustin, check out pioneer premier decks. they seem to be the flavor of the month. i have one and many others and we all love em'. great decks. |
