Buying Kicker 12 '' CompVR's ZBox..which one
Username: Biggyg9712
Post Number: 74
im going to be buying a box on ebay for 2 kicker compvr's which should i get?
http://cgi.ebay.com/ONIX-NEW-12-DUAL-VENTED-SUB-BOX-ENCLOSURE-JL-AUDIO_W0QQitemZ 5812353703QQcategoryZ14945QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ONIX-NEW-12-DUAL-SQUARE-2-0FT-SUB-BOX-ENCLOSURE_W0QQitemZ581 3274793QQcategoryZ14945QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Post Number: 75
anyone?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 158
If you want it to be louder go with the first one, but if you do try to get one with the ports going the other way
Username: Rovin
Trinidad & T...
Post Number: 905
U mean to tell him , with a port on each end rather than both in the middle - right !?
