Old type R NEW type R???
Username: Mixmastaspig
Oknagan, B.C Canada
Post Number: 66
I have 2 12" 1000MAX type R's, I noticed that they have new 1500MAX type R's out...is it worth it to go buy the NEW models, are they that much better...or is the difference not really noticable?....I like the SQL setup.
thanks
Oknagan, B.C Canada
Post Number: 68
Anyone?
thumthump
Dont judge subs by their MAX ratings, use RMS.
The newer type-rs are better than the older ones cuz they're usin better tech like(HAMR) plus their 'rear-end' looks nicer :-)
Username: Audio_paul
Watkins, MN United States
Post Number: 16
yeah its worth it to get the new ones you will notice a diffrence! the tech. is way better than the old ones
Oknagan, B.C Canada
Post Number: 70
K..I'll either sell my OLD ones, or go to a comp with my new amp and try to blow 'em
