I have 2 Kicker CompVR's in a Sealed Box!
Username: Biggyg9712
Post Number: 68
i was wondering if i filled the box with polyfill if the subs would sound better?
i no this is the wrong forum, but the subwoofer one isnt working
Username: Rovin
Trinidad & T...
Post Number: 808
if the box was built a bit smaller than it needs to be - try 1 lb polyfill / cu ft , thats the cheapest way to experiment.
Appropiate thing to do would be to build to a box with the accurate rec specs ......
