Sony CDX-5000X radio suddenly stopped working.....
The radio worked fine yesterday and the cd player works perfectly......?!?
I've removed the unit to check if the antennae wire had shaken loose but it was still plugged into the unit.
I've had the player since '01 and never had a single problem with it since I installed it (other than the notorious skipping!).
Any clues??
